What permissions does a CRIO user need to retrieve or apply an image
I was considering creating a user that could apply or remove a system image using "Create System Image" or "Set System Image". There are a number of options for what permissions I can assign to a user. What is the permission or set of permissions needed to run each of those functions?
Message 1 of 10
(5,135 Views)
Hi nanocyte,
I am afraid I don't get what do you mean with the set of permissions to run the functions. Could you explain further, please?
PedroR
Message 2 of 10
(5,105 Views)
In the web config UI, you can add users and give them permissions:
What's the  minimum set of permsisions I'd have to give "Imager" so that "Imager" can run this code without getting an error:
Message 3 of 10
(5,101 Views)
Hi nanocyte,
This user needs:
GetSystemConfiguration
SetSystemConfiguration
PedroR
Message 4 of 10
(5,089 Views)
I am getting error -2147467259 when I try that. If I log in as admin it works fine. Are you able to create an Imager user and have that user retrieve or apply an image?
Message 5 of 10
(5,084 Views)
Are you getting this error when creating or when deploying?
Message 6 of 10
(5,079 Views)
I get -2147467259 for Create and -2147220323 for Set (code shown above). What errors if any do you see with the nonadmin?
Message 7 of 10
(5,073 Views)
These errors don't seem related to permission. They point to issues with the code and/or the system configuration VIs.
Take a look at your code and make sure you have the variables correctly set (password, user name, etc)
PedroR
Message 8 of 10
(5,069 Views)
I wonder if you also need to have permission to reboot the cRIO.
I think file imaging happens in safe mode and I think you have to reboot to into and out of safe mode.
Message 9 of 10
(4,273 Views)
Hello!
I recommend that you ask this question in a new post on the forum, as old forum threads do not have too much exposition.
Message 10 of 10
(4,258 Views)
