What is the common mode range of the 6033E Daq Card?
I'm reading the voltage accross a 10 ohm resistor in
Differential mode. There is 1 AMP DC current
flowing = 10 volts.
When the UUT fails, the voltage on one side of the
resistor could go as high as 50 volts.
That's why I would like to know if the common mode
voltage of the DAQ is withing 50 volts.
thank you...
\\carlos_diaz
(1,840 Views)
For DIFF mode, V+ and V- in have to be within +/-11V of AIGND. You'll probably have to go with NRSE.
(1,840 Views)
Thanks tnewton:
What is the common mode range for NRSE? for the 6033E
board?
(1,840 Views)
