Veristand deploy error after windows upgrade
I ran a PXIe8840 on Win10pro. Due to company regulations, I had to upgrade to Win10ultimate and the host name was changed. Everything else stayed the same, but now Veristand reports an error when deploying the project stating that the target is not reachable (although a ping works fine). This is the original post - can someone please give me a hint to solve the problem?
• Start Date: 03.11.2020 16:47
• Loading System Definition file: D:\SmartM\VeriSTAND\Projekt\XYZ\Test_M_RT.nivssdf
• Initializing TCP subsystem...
• Starting TCP Loops...
• Stopping TCP loops.
Waiting for TCP loops to shut down...
• TCP loops shut down successfully.
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307850 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: Das Zielsystem kann nicht erreicht werden. Vergewissern Sie sich, dass das Real-Time-Zielsystem läuft und das Ethernet-Kabel mit dem System verbunden ist.
Message 1 of 1
(708 Views)
