06-14-2020 07:29 PM
I am new to FPGA, and would like to use sbRIO 9626 with LabVIEW 2020. The issue is the MAX can find the device, but showing "connected-safe mode (No software installed)" .
I have installed FPGA and RT modules, as well as ISE 14.7. Please let me know how to get out of the safe mode?
Thanks.
06-14-2020 07:56 PM
I guess you haven't finished following step.
Install NI Software on Your CompactRIO Controller
http://www.ni.com/getting-started/set-up-hardware/compactrio/controller-software
06-14-2020 10:03 PM
Thank you very much for your reply. Here is the issue I met when trying to install the software. Seem the sbRIO I am using should run with Vxworks, but I am not sure whether it has been installed. Additionally, the Real-Time is not installed in the target, but I could not find it on the list either.
Really appreciate the help.
06-15-2020 09:01 AM
LabVIEW 2020 is only compatible with CompactRIO 20.0 or above drivers, but CompactRIO 20.0 driver dropped support for sbRIO-9626 along with other older variants. You will need to use LabVIEW 2019 SP1 or below to use sbRIO-9626.
06-15-2020 10:19 PM
Thanks for the help! Problem solved by using 2019 sp1 with NI-RIO 19.1. This is the last version supporting sbRIO9626.
