Using differential signals with 9205 ADC module
I have some differential signals going to an NI 9205 ADC, connected to a CompactRIO, and I am programing the FPGA VI.
In the FPGA VI, there are nodes representing the signals at the 32 pins of the ADC. My question is do I have to program myself the subtraction of the differential pin pairs? For example, I wire Pin 0 and Pin 8 to a subtract function, and wire Pin 1 and Pin 9 to a subtract, and so on?
If not, then for example can I use only Pin 0 and not even have Pin 8 in the block diagram altogether? Then how do I make the ADC know it is being used in differential mode?
(824 Views)
Start the NI example finder and search for keyword 9205. The Example NI 9205 Basic IO.lvproj should answer your question.
Regards, Jens
Kudos are welcome...
(822 Views)
Hi Jens,
Thanks for your suggestion! I really appreciate it. I took a look, and can I confirm with you what I see?
From what I can tell, they created a cluster of settings that include whether the channels are SE or Diff, and made it into a control that can be passed to an FPGA I/O Method Node. Then there's an FPGA I/O node without any logic after it that would subtract signal pairs.
I suppose this means that as long as I pass the info that its differential to an I/O Method node, the FPGA will know, and I won't have to worry about programming any signal-pair differences myself. Is that right?
(811 Views)
Did you look at the FPGA-implementation in that example?
In this the Terminal mode for a specific AI channel is set:
https://zone.ni.com/reference/en-XX/help/370984T-01/criodevicehelp/crio-9205/
Keep in mind that you can only set AI0-AI7 and AI16-AI23 to differential:
https://zone.ni.com/reference/en-XX/help/370984T-01/criodevicehelp/set_terminal_mode_method/
After this configuration the node for that specific channel will hand back the differential value, no need for you to calculate an differences.
Regards, Jens
(778 Views)
