While using distributed clocks I need to work with NI-9216 altogether with the NI-9260 both installed in a NI-9145.
The NI-9216 sampling time is 2,5 ms (400 S/s).
The NI-9260 sampling time is 19,6 us (51,2 kS/s/ch).
This is NI-9145 is an Ethercat slave and I am considering a master cycle in the order of 50 us, using distributed clocks.
The NI-9260 should not have a problem because its sampling time is faster than the master cycle, but the NI-9216 could have a problem.
My doubts are:
Could I still use the NI-9216 with these conditions, acquiring the same data up over and over until its update?
Or will the NI-9216 will output an error because of the sampling time?
Thank you,
