Using CRio NI9265 module as current source
Apologies for the fairly basic question - I'm coming at this from a Chem Eng background rather than an electrical one. I have a CRio 9012 controller with a 9265 0-20 mA output module (among others). The power supply to the CRio is 24VDC. I want to use one of the outputs as an input to a Watlow DIN-a-mite power controller, which will in turn drive a 10A/2.5kW heater.
The datasheet for the power controller states that the input command is loop powered linear current, 4-20 mA DC, requiring a current source with 6.5 VDC available. Am I correct to say that I should compare 6.5 VDC to the compliance voltage for this module (12 VDC max), thus this arrangement will work?
Chris.
(3,463 Views)
Accepted by ChrisTighe
Hello ChrisTighe,
That is correct, the setup will work.
The 9265 will output up to 12 VDC, and your device requires a maximum of 6.5 VDC.
(3,459 Views)
