02-10-2021 04:05 AM
Dear all,
I have been developing a Real-time Labview app where cRIO-9040 is streaming data at 1MS/s from FPGA to the host computer via network streams. On one computer, the discovery of cRIO, deployment and streaming data works flawlessly (which is my office computer😕 ) . Once I move the cRIO to the lab, which also has a decent machine (bought in 2020) , the discovery of cRIO lags, each time I try to even switch to RT vi it would pop up a window that it's trying to connect to the target) and all my network streams work so slow that the RT FIFO's overfill very quickly. Both machines I connect to USB 3.0 port (according to the marking) and I have tried multiple ones on the sluggish machine with no success. Whenever I search for troubles in usb connection I get topics related to overload of cRIO machine or firewall issues, but here these both are clearly not the case as I have a machine where everything works and on the lab machine it works, but just slow and unstable. Would you have any advice on it?
PS I am going to try ethernet on Friday or Monday.
Thanks in advance,
Sergii
03-12-2021 12:37 PM
Hi Sergii,
you have met an interesting problem. Was it solved?
Is the connection faster with Lan connection?
03-12-2021 12:40 PM
Hi Tidad,
Yes, with LAN it works like charm. With usb on this particular machine is troublesome. So we just went for the ethernet connection.
Bests,
S
03-12-2021 12:48 PM
Thanks for the information.
It would be good to know the USB behavior reason.
03-12-2021 12:55 PM
I was unable to figure that out. Especially it was hard to troubleshoot because it was not completely broken. Just slow and time to time loosing connection to the computer. I have tried all version ports on this machine with no difference. What heard from electronics department is that in general USB-to-LAN conversion is rarely bug-free and in general less reliable than true LAN. So I went for it:)
