08-13-2007 04:11 PM
08-14-2007 11:03 AM
Hi Somit,
Thanks for posting to the discussion forums. I assume that you just dont want this startup exe to run when the PXI starts up. There are a couple ways you can go about doing this. First, you can read over this KnowledgeBase which discusses ways to stop it from running. Or the second option is you can ftp to the controller, rename the startup executable and delete it. Then you can deploy any other startup exe that you want to. I hope this helps you out.
08-14-2007 11:17 AM
That answers my undeploy question. Thanks.
However, are there appropriate architectures that we should follow when deploying RT applications? For example, should we remove all of our front panel indicators when deploying a RT startup executable?
08-15-2007 12:27 PM
Hi Somit,
Sorry about that, I guess I just read over that part of the discussion post. There is actually a good Developer Zone article on RT Architecture and programming practices. Also, at the bottom of the article there are links to a RT FIFO example and another link. I think this should help you out. Have a great day!
