09-14-2022 10:09 AM
I apologise for asking a possibly naive question as I am a beginner in CRIO and I have recently been experimenting with the CRIO-9074 for FPGA programming. After connecting my PC to the case with a network cable and configuring the IP address, I tried to install the software for my 9074 in NI MAX, but after opening the Real Time Assistant, there is no option in there to install it. This causes my 9074 to remain in safe mode(no software installed). How can I solve this problem?
P.s. I have installed Real-time(64) in NI package manager, and all the selector switches on the top of the chassis are in off mode.
K
09-14-2022 10:29 AM
@zkli,
The cRIO-9074 is an older device that is not supported by current versions of the drivers and LabVIEW.
NI has a web page that lists what hardware is supported by which software:
https://www.ni.com/en-us/support/documentation/compatibility/09/software-support-for-compactrio--com...
LabVIEW 2019 is the last version to support the cRIO-9047.
09-14-2022 11:29 AM
Thank you so much for your answer.
K
