Two or more cRIO 9074 in daisy chain and behaving as slaves inside the EtherCAT network
Is it possible to daisy chain two or more cRIO 9074 with I/O modules and making them behave as slaves inside the EtherCAT network while also using their capabilities for fast I/O sampling and data processing? To be specific I would need to aquire the data from analog inputs, perform some filtering using the FPGA and post the data on the EtherCAT network. I would appreciate any possible solution based on the NI hardware.
Thanks.
(3,704 Views)
Hello Straki,
Unfortunately, it is not possible. Check the following KB for details:
http://digital.ni.com/public.nsf/allkb/2B09B862059B5502862575280045DA74?OpenDocument
You can use the NI-9144 Expansion chassis to reach your goals. More about NI-9144 expansion chassis:
http://zone.ni.com/devzone/cda/tut/p/id/7300
http://zone.ni.com/devzone/cda/tut/p/id/7299
If you have further questions, please, don't hesitate!
Best Regards,
Matyas
(3,680 Views)
