04-05-2019 03:40 PM
Hi!
Anybody know how to connect the NI 9213 temperature modules to the PC with LabVIEW over approximately 200 meters? I do need to connect 10 modules to the 1 measurement system (160 total measurements channels)
04-05-2019 07:30 PM
Gigabit ethernet can get you 100 meters, so maybe use a POE extender to get you there? If you need 10 modules, maybe 2 CDAQ Chassis?
04-08-2019 08:22 AM
Thank you for the answer! I am new to this kind of systems.
If I am right understood, the temperature measurement modules (like NI-9213) had to "plugs" into the CDAQ Chassis (like cDAQ-9181)
and this chassis can connect via ethernet to the switch and then to the PC with controlled software like LabView?
Is this idea correct? (I like the 1 slot chassis due to needs for the distributive over the football size field with more then 160 thermocouples)
Thanks, Vadim
04-08-2019 11:45 AM
Yes, your understanding is correct. You might also want to consider one of the WIFI chassis if that's an option for you.
04-08-2019 12:26 PM
Thank you for clarification!
