11-18-2008 05:30 PM
I am pretty new to programming on the RT target, and I'm running into a problem. I am using a cRIO-9074 to acquire data and I am trying to log it using the TDM Streaming VIs. Unfortunately, I am getting this error:
Error 53 occurred at TDMS Open in Test_TDMS.vi
Possible Reason(s):
LabVIEW: Manager call not supported.
The VI is attached, and writing to a normal file works fine.
Thanks a lot!
Solved! Go to Solution.
11-18-2008 07:24 PM
11-18-2008 10:47 PM
03-06-2009 07:54 AM
Herbert,
I´m using LabVIEW 8.5.1 and compact field point cFP-2220 and I get the error 53 Manager call not supported when trying to write TDMS file stored in a FAT 32 hard disk connected to the USB in the cFP-2220. The path I use is "u:\nombre.tdms"
Please help
simbani
03-08-2009 08:02 PM
Simbani,
cFP-2220 is running VxWorks as an operating system. You would need to either use the VI based API or update to LV 8.6.
Herbert
