09-18-2013 12:53 PM
09-19-2013 08:36 AM - edited 09-19-2013 08:37 AM
Can you post a simplified version of your VI that reproduces the problem. Also are you using static or DHCP?
09-19-2013 01:24 PM - edited 09-19-2013 01:29 PM
I am using static IP addressing on the device. The sbRIO communicates just fine with the network. It's only this configuration change that hiccups.
Heres an image of the code that fails. This snippet fails all by itself even
09-19-2013 03:00 PM
Out of curiosity if you use that same property node, what does it return as the IP address. Do you get what you expect or something like 127.0.0.1?
09-19-2013 04:20 PM
09-20-2013 12:46 PM
We have reproduced what you are seeing and R&D is investigating this issue. Currently, you can change the comment and hostname of the sbRIO successfully by running this code from a Windows computer (and targeting the sbRIO on the Initialize.vi). It also runs successfully on the sbRIO if the IP settings are set to DHCP. Will either of these options work with your application?
09-23-2013 01:25 PM - edited 09-23-2013 01:26 PM
R&D is working on implementing a fix for this bug. In the meantime, here is a workaround:
If you write the correct IP address in addition to writing the Hostname and the comment, then your save will be successful. We realize this is not a very pretty or intuitive solution, but it should work until a fix is implemented.
09-23-2013 04:38 PM
09-23-2013 04:41 PM
09-23-2013 04:54 PM
The other state of the case structure is mostly blank with a false wired out to the stop terminal. Hopefully, this code will do what you need it to for now.
