System Exec with ping freezes when called from a webservice
I have a VI that calls System Exec.vi. The command sends out a couple pings: ping -c 2 localhost. It works fine when I run it outside the webservice but once I call it from within the service, it hangs indefinitely. Here's simple code reproducing this with a 9603 and LV2022Q3
CLED (2016)
(435 Views)
I made a service request for this issue and we weren't able to find a resolution but we found a couple possible workarounds:
  • Sending just 1 ping was fine. e.g. ping -c 1 -n -W 1 127.0.0.1.
  • We also discussed, but I did not test, moving the code outside the webservice and transferring data with a global or a named queue.
The CAR for this issue is: 4134037
CLED (2016)
(159 Views)
