08-10-2021 06:23 AM
I've got a problem as stated in the subject, with only one RS-232 and one Ethernet port available on cRIO-9075. The final DAQ application needs to run headlessly.
From what I have gathered, serial-to-USB adapters (that would not just physically connect but actually work in the direction required) are now rare or/and costly. So, I'm focussing on Ethernet-to-USB adapters but it's also not quite clear which ones will actually work in the headless mode, without a computer connected (I've been looking at 1, 2, 3 for instance - #2 seems the best bet?)
Has anyone had any experience with a similar problem and can offer any advice?
There are two additional factors: (1) On occasions, it would be useful to also connect a PC to the cRIO, to run a simple plotting application. This probably means using an Ethernet hub/splitter - I wonder if and how that would affect the main data storing application, (2) No access to mains (a battery will be needed) so adapters not requiring a separate power supply are preferable - but that's not a hard constraint.
Many thanks!
08-11-2021 07:23 AM
Hope you haven't ordered anything yet.
1 is just a USB over twisted pair cable extender, so surely it won't work.
2 is a print server, although it can be used for USB drives, but it's software supports only Windows and Mac, so it won't work too
3 is the same thing as 1, but it can work for longer distances.
From what you have described, you have few options
