Splitting the sensor analog signal to two bnc terminal block
I currently have one LVDT sensor signal that has to be used with two BNC terminal blocks, BNC 2111 and USB 6211. Former is used for Labview data logging while the later is used for controlling a DIC camera.
It there any way to split the signal so that both the terminal blocks could be fed with the same signal without any buffer.
Thanks in advance
Message 1 of 1
(1,487 Views)
