01-20-2020 12:31 PM
DAQmx Read is being "slow" for me and I don't see why.
I've put a DAQmx Read into a timed loop where the frequency of the loop and the sample rate of the DAQmx Input task are equal at 5kHz. When I check the duration of the DAQmx Read VI, I find that it is consistently close to the period of the timed loop. I'd like to perform some processing and control off inputs but I can't do that if the Read VI's take up 3/4+ of the loop period.
I've looked everywhere and I haven't noticed anything that would cause this behavior. If it's "a feature, not a bug" to not retrieve data as quickly as possible, I haven't found a way to tell it not do that. My DAQmx Write VI's had durations of about 5 µs, which is about where I had expected the DAQmx Reads to clock in at.
Here's an example of the behavior I'm referring to:
The above example was timed with this setup:
The input task is configured to use a PXIe 6612 (Slot4) and the timing stuff (pulse train generator and timed loop source) are on a PXIe 6356 (Slot2). The whole thing is running on PharLap ETS 13.1 with a PXIe 8135 as the controller.
- A. Brooks
01-20-2020 01:29 PM
I've gotten the DAQmx Read duration back to where I had expected it to be, but I don't understand why the code would be operationally different.
I changed:
to:
After the change, the DAQmx Read duration is about where I expected it to be between 2µs and 4µs. I don't understand why the change would have a significant impact though. If someone could explain for documentation purposes, I'd greatly appreciate it.
-A. Brooks
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
