11-07-2012 03:32 AM
hello,
I´m trying to create an Signalcreator (Sine Signal) on my AnalogOut.
The Examples offered by Labview, are all on FPGA. 😕
I Added an part of my Project (including the TimedLoop) to show you where the Generator should be working.
I´m not sure how to generate the correct Signal (sinus with changeable frequecy), depending on the Periodtime/ScanTime of the timed-loop.
would be great if someone could help me.
Greetings
Solved! Go to Solution.
11-08-2012 09:06 AM
Hi Marmo,
Point by Point operations are very suitable for generation Signals on RT level. You will find the VI in signalprocessing/ point by point transformation.
For each iteration of the loop a scalar value will be generated be aware of frequency settings for the VI.
You configure the Delta t via the timing VI.
Please check the attached screenshot.
Kind regards,
Rup
NI Germany, AE
11-09-2012 06:24 AM
Thanks a lot.
found that example day before :))
I connected it this Way....(using the Timed Loop Time)
Greetings
