Your question should be posted under "Measurement Devices >> Multifunction I/O" instead of "Real-Time DAQ" because the PCI-MIO-16XE-10 board is not a real-time device. The category "Real-Time DAQ" is reserved for 7030 real-time devices.
The PCI-MIO-16XE-10 multiplexes channels across one amp and one A/D converter; therefore, it cannot perform true simultaneous sampling. Consider using the SC-2040 accessory, which has 8 simultaneously sampling differential amplifiers. Alternately, you can purchase a different board like the PCI-6110, which can perform true simultaneous sampling because it has individual A/D converters and amps for each channel.
