SMB Connector D I/O on cRIO 9014
The manual states:
"The software that supports GPS drift-correction and other digital I/O through the SMB connector was not available when this manual was published. Please contact National Instruments for more information"
Through my project explorer I do not see any way to programmatically control the output of the SMB connector on the cRIO.
I only require one Digital Output line and would like to use this connector.
Is the trigger on the cRIO-9014 usable at this time?
William
(4,763 Views)
Hi William,
I'm happy to say that the SMB connector on the cRIO-9012 and 9014 can now be used as a digital I/O line.  VIs to set, get, read, and write the SMB pin mode, along with example code, are attached in "901x SMB 8.2.zip."  You can ignore the search for vx_exec.out when opening the examples.
The KnowledgeBase article Using the SMB Connector for Digital I/O on cRIO-901x Controllers provides more details on drift correction if you decide to someday use the SMB pin for that purpose.
Jennifer R.
Applications Engineer
(4,748 Views)
Excellent.
This will do just what I require.
Thank you,
William
(4,735 Views)
How can I use the SMB connector of 9014 in LabView 8.5? These vi's do not work without vx_exec.out.
(4,328 Views)
Please create a new thread for this post--this thread is no longer in use. Also, please refer to the knwoledgebase article referred to by Jen R. It tells you about how to deal with vx_exec.out. you basically need to ignore that item in the search.
Ipshita C.
(4,293 Views)
