07-10-2014 12:49 AM
Hello everyone,
I have 5 SBRIO- Cards (SBRio 9636). I want to use them in our Campus- network, but I have problems to configure them.
The main problem is, that no netrwork LED is on, when I plug in the network- cable.
The first board, had the same problem, and I was playing with a lot of things for days and than it ran, everything was fine. But I have no idea, what the thing was to get the board running.
I don't want to have the same trouble with the second one.
When I plug the second board to a local router everything seems to be o.k.
I can see it in the local network, but when I plug it to the campus network the LAN- LED's stay dark.
Has anyone tips for me?
Greeting, Ruediger
07-11-2014 10:00 AM
Hi Ruediger
In page 48 of the manual there are some troubleshooting steps that you could try.
http://www.ni.com/pdf/manuals/373378d.pdf
Let me know if that didn't work 🙂
Best Regards
07-15-2014 02:16 AM
Hi MhM4054
things are more complicated.
I wanted to see what is going on, by watching the COM1 port. But, as I only have USB- ports on my computer, I used a USB serial adaprter. Whith using Putty I was not able to see any comunication.
But using this Cable had one side- effect.
I could get the communitcation running when I do the following:
*pressing the RESET- button for 5 secs with COM- cable connected and Network cable in.
*waiting for the LED to flash 3 times
*unplugging the serial- cable starts the network activity, but there is not correct IP- address
*doing this 3 steps a secnod time
and then
*pressing the RESET- button short with the serial cable in and removing it.
Now the board is pingable and has the right IP
BUT if I boot the board once more, it is not using the network adapter anymore, all the network lights are dark.
What might be the reason for this behavior and what is the soulution.
Best regards, Ruediger
