10-16-2009 11:17 AM
10-20-2009 03:39 AM
http://digital.ni.com/public.nsf/allkb/B9571226E90A0ECE86256FDB00681951?OpenDocument
this would help.
try booting it in safe mode.
Also, set the ip address reset button ON to set the ip address to 0.0.0.0. You need to make sure that the sbRIO and your computer are on the same subnet.
10-20-2009 12:22 PM
10-20-2009 03:29 PM
10-21-2009 01:38 AM
I believe blissful brings up a good point regarding the version of RIO driver. I had a similar problem with a cRIO-9074, and found out that I needed a newer version of the NI-RIO.
According to this page, you should have minimum of LabVIEW 8.5.1, FPGA 8.5.1, Real-Time 8.5.1 and NI-RIO 2.4. But note that a number of regular cRIO controllers require NI-RIO 3.2.1, perhaps your sbRIO should be on the list as well.
If you are already at 8.5.1, 8.6 or 2009, you should be covered, but I would install the latest version of NI-RIO (3.2.1) from here on a test computer to see if that's the issue. Sometimes these documents don't get updated correctly or as quickly as we'd like. 😉
I'll bet a candy bar or an apple that the latest version of NI-RIO solves your issue.
10-22-2009 12:21 PM
