Replicating cRIO-9074 image
We are using cRIO 9074 and wanted to backup and clone the real time image, FPGA bitfile and real time application. This project was built with LabVIEW 2010. I see I can use the Replication and Deployment Utility (RAD) but can I use the latest version, 16.0, or will I need an older version built for LabVIEW 2010?
(898 Views)
Accepted by topic author Melono
Hi there,
Yes, RAD will work with your cRIO-9074, regardless of the LabVIEW version that the code was written in.  You can think of RAD as like ghost or Clonezilla, it makes an image of all the files inside the cRIO-9074.
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
(811 Views)
