07-02-2021 02:49 AM
I used real-time timed loop to get acceleration data from NI 9234 (cRIO) and loop timing source is 'scan engine'.
The scan period is 1ms.
But when I checked the saved data, the period was not 1ms, it was 0.004~0.005s.
What is the problem?
Thank you.
07-02-2021 04:51 PM
That IO module cannot have its sample rate set to an arbitrary value, but it is configurable.See the data rates section in this:
https://www.ni.com/pdf/manuals/374238a_02.pdf
You would need to set the timed loop to match the sample rate you choose. But you may also need to use FPGA rather than scan engine.
07-04-2021 07:09 PM
Thank you!!
