Real-time scan resources deploy problem
Hi, evryone!
When I try to deploy c-modules I become error: "The current module settings require NI Scan Engine support on the controller."Deploy_Error.PNG
But Scan Engine has been already installed on my controller.
I've already tried the following:
1. Restart controller (Does not help)
2. Reinstall Software on controller (Does not help)
3. Format Disk and Reinstall Software on controller (It worked 1 time, then it stopped helping)
4. Change module Program Mode  (Does not help)
Please, help me to solve this problem.
(244 Views)
 I found a similar solution: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJIuSAM&l
But in my case it doesn't work(((
(195 Views)
Checked out DAQmx. When I put the module in this mode and try to run Test Panels .. it gives an error -50150.
(180 Views)
I tried to run FPGA. The program compiled but refused to run, saying that Chasis was in scan mode.
With this, I configured all modules to FPGA mode.
(178 Views)
Did the cRio formatting and reinstall NI CompactRIO 20.0 (for LV2019). During installation, I did not change the selected packages, I left everything as it was by default. Updated the firmware. As a result, cRIO started working in FPGA and DAQmx modes. But in RT Scan mode, everything also does not work, because Scan Engine was not installed.
(164 Views)
Accepted by EgorKarlin
Hello @e.karlin
The reason for this error might be various versions of LabVIEW installed on your PC. As long as when installing Scan Engine version dependent dlls are being used from C:\Program Files (x86)\National Instruments\LabVIEW 2019\resource\ScanEngineHandlers and a conflict occurs, try to repair software from NI Package Manager or reinstall it.
(144 Views)
