11-23-2020 03:42 AM
Hi, evryone!
When I try to deploy c-modules I become error: "The current module settings require NI Scan Engine support on the controller."
But Scan Engine has been already installed on my controller.
I've already tried the following:
1. Restart controller (Does not help)
2. Reinstall Software on controller (Does not help)
3. Format Disk and Reinstall Software on controller (It worked 1 time, then it stopped helping)
4. Change module Program Mode (Does not help)
Please, help me to solve this problem.
11-24-2020 06:54 AM
I found a similar solution: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJIuSAM&l
But in my case it doesn't work(((
11-25-2020 06:01 AM - edited 11-25-2020 06:02 AM
Checked out DAQmx. When I put the module in this mode and try to run Test Panels .. it gives an error -50150.
11-25-2020 06:05 AM
I tried to run FPGA. The program compiled but refused to run, saying that Chasis was in scan mode.
With this, I configured all modules to FPGA mode.
11-26-2020 03:06 AM
Did the cRio formatting and reinstall NI CompactRIO 20.0 (for LV2019). During installation, I did not change the selected packages, I left everything as it was by default. Updated the firmware. As a result, cRIO started working in FPGA and DAQmx modes. But in RT Scan mode, everything also does not work, because Scan Engine was not installed.
11-27-2020 07:14 AM
Hello @e.karlin
The reason for this error might be various versions of LabVIEW installed on your PC. As long as when installing Scan Engine version dependent dlls are being used from C:\Program Files (x86)\National Instruments\LabVIEW 2019\resource\ScanEngineHandlers and a conflict occurs, try to repair software from NI Package Manager or reinstall it.
