03-12-2019 06:01 PM
Sorry for my English.
If allows I have 2 questions about working with sbrio-9631 Board :
for example, I took the analog input 24 (AI24). a potentiometer is connected to it.
I tried to do something, but it didn't work. show test1.7z
Is it possible to connect this sensor directly to the analog input of sbRIO-9631 Board?
thanks in advance for the answer.
03-14-2019 12:58 PM
I saw this in the data sheet:
A wheel load of 400 pounds will produce a minimum output signal of
250 mV, at 70°F and 55 mph for a proper installation
Which is promising. It might work fine out of the box. My only concern is that I didn't see an output impedance. There's a small chance you'll need an op amp to buffer the signal.
03-15-2019 04:10 AM
Thank you so much nanocyte!!! I used tl071cp low noise JFET input, and high input impedance.
03-15-2019 12:07 PM - edited 03-15-2019 12:08 PM
I'm not sure that that op amp would have a higher impedance than the 9631 so you might want to try without. But, if it works, it works!
03-15-2019 12:21 PM
Nanocyte thank you for your advice, for now I can not test, on monday I'll see what it.
