08-16-2007 12:24 PM
We are trying to us a PC as a real time target to perform data acquisition with an E series DAQ board.
The PC we are using is from Superlogics, model: SL-4U-CL-965G-HA.
The motherboard is an Intel DG965RY.
The NI system evaluation routine gives the error: “No PCI BIOS present”.
Labview version is 8.2
Does anyone know how we might get around this error?
08-17-2007 03:10 PM
08-21-2007 12:19 PM - edited 08-21-2007 12:19 PM
Message Edited by arvin labrat on 08-21-2007 10:24 AM
08-22-2007 09:05 AM
08-22-2007 10:18 AM
Steven
Thanks for the explanation. It's what I thought but it's always nice to have confirmation.
Eric
08-23-2007 10:44 AM
Eric, Arvin,
I wanted to let you know that with LabVIEW Real-Time 8.5 we have gotten rid of
the PCI-BIOS support requirement. In the past we relied on the BIOS to perform
the PCI device enumeration, but since BIOS manufacturers have been taking
functionality out of their code (therefore dropping support for several legacy
operating systems) we decided to perform the PCI device enumeration ourselves.
We have tested this on several machines, including PXI and desktops known not
to have the PCI-BIOS support.
Additionally, we have added support for AHCI-compliant SATA hard-disk
controllers, so if your BIOS supports setting up your SATA drive in AHCI
mode, you should be able to use it. Otherwise you would need to look for a SATA
Legacy or Compatibility mode in your BIOS, and if that is not there either,
you'll have to fall back to a PATA drive.
We also increased CPU support, covering most of the currently available x86
processors, including multi-core ones. As you might already know, one of the
key features of LabVIEW Real-Time 8.5 is Symmetric Multi-Processor (SMP) support,
which allows you to make the most out of all processors on the system while
still guaranteeing the determinism of a Real-Time OS.
We now support an additional set of Ethernet chipsets, based on the Intel Tekoa
family of gigabit adapters (8257X). Not all of the 8257X variants are
supported, so we'll try to update the KnowledgeBase with the details.
Most of this information could not be disclosed until a couple of weeks ago, so
we are currently in the process of updating the respective web documentation.
I hope this helps,
Alejandro
08-23-2007 02:22 PM
Alejandro
That's great to hear. I looking forward to reseving my service update to try it out.
Thanks again
Eric
