09-01-2016 05:36 AM
crio 9073
i am running scan interface mode with 9205 AI module, saving the data in TDMS format. while in open tdms, i gave the file path as c:\ip address\ filename. then it is saving in the internal memory of crio. when i build the exe with same file .tdms file is not saving in the internal memory of crio, it is saving in the c-drive of computer. so how to save the file in internal memory of c-rio with .exe
09-01-2016 11:57 AM
Well, C:\ does not even exist on the cRIO-9073. I recommend you give this article a good read: Working with File Paths on Real-Time Targets
09-07-2016 05:00 AM
i am a beginer i couldnt get much
is this process is ok
as i mentioned earlier this is working fine,bulding exe with the same it is saving in my computers drive.
