09-25-2008 11:04 PM
I've built a stand-alone application and set it as startup. Is it possible for a VI running on RT to distinguish whether its running from a stand-alone application?
The thing is, when I control the VI from PC, I need to monitor some data (for debugging) but when runnning as stand alone, I dont need that as the data keeps accumalating and will run out of memory sometime. If there is spme kind of a property of VI that can be used to determine if its a stand-alone app, I can create some logic so that VI behaves differently when I build the stand-alone app.
09-26-2008 06:24 AM
09-28-2008 11:10 PM
Thanx for the reply.. I'll try it out..
