RT application doesn't talk to FPGA properly when run as startup
I recently experienced this same issue and found that it seems to be an issue with Shared Variables and Type Defs.  I selected (check mark showing in radial box) Disconnect type definitions in the Additional Exclusions category of the build properties (right-click your build and select properties).  All the other Additional Exclusions were selected as well.  I deployed the application with Run as startup and it deployed correctly.  Hope this helps whomever experiences this same issue.
Message 11 of 11
(1,391 Views)
