Hello everybody,
I'm trying to simulate an FPGA VI that targets a PXIe-7975R board with an NI 6584 IO Module. Simulating the FPGA VI itself works okay, however I also want to inspect I/O together with simulated host data.
To accomplish this, I created a host VI with an FPGA Desktop Execution Node, selected my Top Level FPGA VI - but the IO Module Ports and Pins are not listed under "Available Resources". The IO Module status (IO Module Properties -> Status) rightfully says "RIO device not detected." as I run this simulation on a regular PC - but that should not affect Simulation of those I/Os, right? I *can* see Basic FPGA I/Os, if I add them via "FPGA Target -> New -> New FPGA I/O", which then appear in the Execution Node Configuration Dialog. However, I can not add IO Module I/Os there.
To provide a minimum working example, I'll be showing what works and what does not. You can find attached pictures of a simple project configuration, FPGA and Host VIs as well as the FPGA Execution Node Configuration Dialog (where I would be expecting the IO Module Pins as I see them in the Project Explorer).
I'm not sure what I am missing, so maybe somebody can tell me...
