Proportional and Servo Valve Control by using NI 9264 and cRIO 9014
Hi Andyclegg,
Thanks so much. I just figured that out now.
Thanks once again
Message 11 of 13
(1,878 Views)
Hello Micahdan,
I am trying to controle a proportional valve using Burkert type 8605 controller. The challenge is that the output pressure should be sinusoidal. I am not sure where to start and how to vary the PWM to generate a sin wave pressure. Do you have any idea? How did you create the block diagram for this controller?
Message 12 of 13
(1,282 Views)
How are you using NI 9264 module? In aFPGA mode or in a Scan mode?
There are multiple examples in LabVIEW example finder that show you have to generate a PWM signal in LabVIEW clik Help>> Find Examples
Message 13 of 13
(1,274 Views)
