07-10-2019 10:08 AM
Hi.
In cRio platform, when configuring an I/O variable, it is possible to define also the engineering unit.
Is there a way to programatically read these defined units?
Thank you
Labview 2019, DSC module, RT module
07-11-2019 09:36 AM
Looks like you should be able to do it by wiring a reference to a Property Node for your Shared Variable since you have DSC Module.
http://zone.ni.com/reference/en-XX/help/371618K-01/lvdscprop/sharedvariableio_p/
Looks like Scaling:Units is the one you're looking for.
Hope this helps!
07-11-2019 10:08 AM
Hi.
A strage behavior is happening. By using Shared Variable IO Property i can read many properties, but when i select "description" property or "units" property an error is occurring.
