Has anyone noticed problems with using larger arrays with a dll on RT?
I am using a dll files to generate a motion path for a 4 axis machine. I use the Call Library Function Node to run the dll and pass in 4 arrays to store the points. When the array size is 2500 and I run the dll on the host, everything runs fine. When run on the target, the target disconnects and I have to reset it before I can connect again. If I drop the array size down to 1000, the dll runs fine on the target.
Has anyone else had this problem? I am doing something wrong or is RT limited to small arrays?
thanks
