Problems using example code.
Hello everyone,
I'm trying to run the Velocity Control (open loop) for NI 9501. I've included the setup of the project below.
However, when I try to run the real time code, I am not able to compile it due to broken links in the code. I've attached the description of why this happens.
Thanks!
(6,084 Views)
Figured it out. Had to change the FPGA file that the real time file accesses.
(6,076 Views)
Hi Mswn!
I'm starting to learn about CompactRIO and I'm trying to develop an application. I have a sbRIO 9606 and I'm trying to implement some exemples that I found on NI website  but it has been a bit hard for me due my lack of experience.
Can you tell me how you have learnt? If you used some tutorials?
Any tips would be appreciated.
Thanks in advance.
(5,987 Views)
Hello Reimon,
You should consult the following link for a guide on starting out with your card.
NI LabVIEW for CompactRIO Developer's Guide
http://www.ni.com/compactriodevguide/
In the future, you should try and create a new post for any issue you run into in order to keep things organized.
I hope this helps!
Andy C.
(5,975 Views)
Hi Andy C.
Thank you for the tip. I'll check it out and for sure I'll come back with a lot of doubts.
Regards.
Reimon.
(5,965 Views)
