07-09-2020 11:49 AM
I have a brand-new cRIO-9042 and all I'm trying to do is log in to the machine so I can install the base software. I'm able to log in and set permissions through the NI Web-Based Configuration client without issue, but using the same usernames and passwords through the MAX login portal gives me an "incorrect username or password" error. Anyone else ever have this issue or something similar?
07-12-2020 04:44 AM
Hi ajwild
Why dont you use default username and password to log in? username: 'admin' & pass: ''(let it blank).
Reza
Application Engineer
07-13-2020 07:39 AM
That's what I've tried, it works fine to login this way through the web client but I can't login with the same information via NI MAX.
04-13-2022 07:59 AM
I'm having the exact same issue, was there any resolution to this?
I've tried everything from cRIO firmware upgrade, to NI software upgrades/downgrades, uninstalled all NI software and started fresh, but every single time I cannot "Log In" via NI MAX to install and update software on the cRIO. Although I am able to login and access the cRIO via the web configuration.
Testing on a known working machine, I am able to log in over NI MAX, so this leads me to believe the issue is local to my machine - but would like to know why my specific machine cannot access the cRIO through MAX?
04-13-2022 09:39 AM
I ended up just using a different PC to login and configure the cRIO with NI MAX. I believe the issue is something to do with some local IT firewall that only applies to desktop PC's at my company, as my laptop works fine for logging in and installing/updating software on the cRIO. Would be nice to find a resolution so I didn't have to switch back and forth between PC's but to this day I haven't found one.
04-13-2022 10:30 AM
Yep, this is the conclusion I came to as well.
I'm going to try to work with my IT dept to see if we can unblock whatever ports seem to be blocked on my machine.
04-15-2022 02:52 PM
It appeared the issue was with the windows environment variable settings for my local http_proxy. Once I deleted these env variable, NI MAX can now log into the cRIO and add/remove software!
