Reply
Problem with analog input/output sbRIO 9626
I have a problem in reading/writing to analoge input/output pins in my sbRIO9626. I have emplyed the code as in the attached image. When I run the code, I receive only "zero" from the analog input without any flactuation. If I send any value to the analog output, I see the output is zero voltage too. The other pins (i.e. digital input/output) of the board are working well.
Any suggestion for this problem?!
Thanks.
Khalick
(306 Views)
It would be useful if you attached your project file and VIs so we can try and reproduce that behavior.
You seem to have a coercion dot on your AI data. That might be worth looking at.
You might want to double check that the code is actually running by connecting a "not" to a feedback node and creating an indicator for the output.
(263 Views)
