04-25-2018 11:06 AM
I have a problem in reading/writing to analoge input/output pins in my sbRIO9626. I have emplyed the code as in the attached image. When I run the code, I receive only "zero" from the analog input without any flactuation. If I send any value to the analog output, I see the output is zero voltage too. The other pins (i.e. digital input/output) of the board are working well.
Any suggestion for this problem?!
Thanks.
Khalick
05-02-2018 12:10 PM
It would be useful if you attached your project file and VIs so we can try and reproduce that behavior.
You seem to have a coercion dot on your AI data. That might be worth looking at.
You might want to double check that the code is actually running by connecting a "not" to a feedback node and creating an indicator for the output.
