Hello ,
I have some problems using labview driver with a datataker model 500 if someone could help me, it would be great!!!!!
I am using a datataker 500 to collect datas by the labview driver version 1.00.
I am using labview version8.2.
I connected the dataker by a RS32-usb cable to my computer.
It is recognized in the visa programm in the sofware Measurement
and Automation. In Labview, I chose the good visa ressource name in Labview where
there is a little icon to indicate that the datataker is well recognized by this port.
I am using the driver high level aquirerealtimewaveformthruserial.
I followed the exemples given in the help. But I replaced by a
voltage measure because I do not use a thermocouple as in the exemple
given online.
http://www.datataker.com/products/Labview/Introduction_dataTaker_Instrument_Driver/getting%20started...
When I run Labview I have no errors but in the exemple it is said that it should stop after 60 s.
In my case Labview never stops and I do not have any graph on the XY graph.
During the simulation I placed a 'retain wire values' which does not indicate anything when it is running.
Furthermore, I highlighted the execution and I have a green arrow situated on the driver but nothing happens.
I have already tried with the exemple highlevelrealtimeaquisitionserial but same problem no signals received by my computer.
Is someone could help me please?
Thank you in advance
