Problem about using PCIe-1429 in RT ETS
I installed the IMAQ 3.6 to the ETS RT target, After that, I try to find the PCIe-1429 in the target, When I open the "Remote System\RT target\Devices and Interfaces\NI-IMAQ Devices\img0: NI PCIe-1429" in Remote systems in MAX, There comes an error dialog box.
Error 0xBFF60140
The requested FPGA bitstream file could not be found.
My current version of LabVIEW and Real-Time Module are 8.0, How can I fix this error? I also wonder where I can install my camera file?
Thank you very much!
Haifei
(3,956 Views)
RealTime support was just added in NI-IMAQ 3.6 so it should work.  The bitstreams should now be automatically downloaded to the target.  Check the ni-imaq/bin/ folder on the target. Copy all of the .dat files in ni-imaq/bin/ on the host to the target manually if they're not already there. If that fixes the problem, then there's an issue with remote configuration.
Christopher W.
(3,943 Views)
Hi, Christopher
That's the problem, there is no .dat files in target. After copying, it works now, thank you very much!
Haifei
(3,924 Views)
