Powering cDAQ 9178 off of an external power supply
I'd like to power my cDAQ-9178 using an external 12 V power supply and not using the power supply provided by the manufacturer. Is there a way to safely connect my external power supply to the cDAQ-9178 to do this or does NI sell a connection with flying leads that I can connect to my power supply? I want to do this because I am placing my DAQ in a weatherproof container and I will not be able to easily run my power supply outside the container when it is closed.
(2,479 Views)
Accepted by topic author mshinn
Your cDAQ chassis should have come with a screw terminal connector for the power.  If you lost it, give your local rep a call.
GCentral
(2,465 Views)
