05-08-2024 09:42 PM
Before, there is baudrate option in xnet module. And I just input 125000 as the baudrate for the program. After the NI-XNET updates, it is required to use baudrate64 option. So what should I input for 125000 in this case.
I have read this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIf5CAG&l=en-VN. And it seems that I can choose different options to choose baudrate 125000. It seems so complex to me. I just only need to input 125000 the same as 32 bit version of NI-XNET before. Can anyone help to teach me? Thank you very much
05-08-2024 10:38 PM
Just wire 125000 to it. You only use the complex value (that can be obtained from NI-XNET Database Editor) if you want to set a custom sample point, which only matters at a higher baud rate of 500k and above.
