Pinout for c series module 15 pin connector
I have an sbRIO and I suspect one of the ports on it is broken. Is there a pinout I can reference so I can see any obvious indicators of this. The sypmtom is that if I put a module on that port, the module is not detected. The module is detected on the other two ports.
CLED (2016)
(3,623 Views)
If one port doesn't work and the rest do, it seems like it might be broken.  You are probably best off calling into support to troubleshoot/RMA the board if necessary.  Otherwise, we can't really help much on here without more information such as which sbRIO you are using, which port, which module, etc.
(3,612 Views)
