Hi, manora,
I just want to double-check with you, is the file system NTFS or FAT32? It definitively needs to be FAT32 if you have an 8187, otherwise LabVIEW RT will not work with it. I asked again, because you are saying that you use the Recovery CD to change the file system to NTFS (?). When you use the Recovery CD, it actually doesn't install the LabVIEW Real-Time software on the controller, that process needs to be done from MAX, from Remote Systems.
If you are still getting this error message, I will recommend installing one software component at a time. Start by selecting LabVIEW Real-Time 7.1 from the select components list, and if that goes right, then proceed with the rest of the components.
Let me know if anything goes wrong. Have an excellent day!
GValdes
