ni.com is currently experiencing issues. Support teams are actively working on the resolution.
04-17-2023 04:25 PM - edited 04-17-2023 04:28 PM
Not sure if Real-Time Measurement and Control is the right place but...
We have cRIO-9045 LV20.0.0 that we need to keep in time-sync with a separate non-NI Linux system that is operating as a PTP (1588) master. Going through the discussion forums and white papers I cannot locate any information on how to make this work. I have installed the NI_TimeSync Time Reference for IEEE 1588-2008 20.1.0 package on the cRIO. I have also read through this (https://www.ni.com/en-us/support/documentation/supplemental/17/monitor-and-configure-time-synchroniz...) white paper and tried to use the API.
Could someone please give me some guidance on how to do this?
Thank you
04-18-2023 05:52 PM
After installation of newer versions of NI-TimeSync on the cRIO, IEEE 1588 is enabled by default on the cRIO's Ethernet ports. (Reference: Enable IEEE 1588 on cRIO)
You can use the shipping example from Help >> Find Examples... >> Hardware Input and Output >> Timing and Synchronization >> Time-Based >> Configure and Monitor 1588.vi
Configure a high value of priority (or lower priority) and your cRIO would be synced to a 1588 masterclock.
04-18-2023 06:38 PM
OK, did that. I am assuming this is the vi Monitor and Configure Time References.vi as the one you mentioned did not exist by that name. What do I put here. The drop down only populates with NI resources.
There is nothing to select here
