PCI-6110
I have got card PCI-6110 and using software Delphi 5 (ComponentWorks). My problem is: I generate sequence external signal clock (1 MHz) to control switch. I would like to sampling same signal (for example: 10 samples) only when control signal is on high level.
(3,245 Views)
Hello;
I didn't get what your application needs are. Could you be more specific about your application so I can give you a better advise?
Thaks
Filipe
(3,245 Views)
