I am using LabVIEW 8.5 and cRIO 9074 with 9263 (AO) module.
I
have an array being generated in my RTCode as a result of an
integration. I have to send this signal as output through FPGA,
however, I realize that we can only send single elements out of the
FPGA, and that too of fixed point data type.
Then how do I send this array out through my 9263 module?
Even you can put an array as a control, but it's not recommended, since it takes much more resource to compile it (a lot more gates consumption).
I've an experience compiling a program with 100 elements array with more than an hour compile time while changing an architecture (remove array) take about 15 minutes.
