08-18-2008 06:17 AM
On CompactRIOs NI 9012 and NI 9014, I can see some files accumulating in the directory C:\tmp. Essentially, xml files and log files.
Should I have to clean these files on a regular basis or will the system clean them by itself?
Thank you for your answers.
08-19-2008 05:11 AM
The cRIO controllers will accumulate up to 32 files in the C:\tmp folder.
Once it has reached 32 files, the files will be cleaned up.
Please notify us if this shouldn't be the case so we can investigate further.
Also be aware that many files in you C:\tmp file may indicate that your application is creating error.
Have a look at the contents of your log files to be certain.
08-20-2008 08:24 AM
I have indeed only 32 files with a "txt" extension + "lvrt.out_8.5.1__cur.txt" + "lvrt.out_8.5.1__log.txt".
Unfortunately, I have also 118 files with an "xml' extension. Here are two such XML files attached (note that I appended the "txt" extension in order to be able to send them to this forum). Will these files be also cleaned up?
Regards
08-21-2008 05:16 AM
